October 3, 2010, 07:56 |
Calculate Drag force for flat plate
VINH NGUYEN
Rep Power: 16 |
Hi all,
I'm finding a drag force for a flat plate (very thin) in 2D that is perpendicular to free flow direction. In this case, the pressure force is much bigger than the viscous force, so I wonder if I can use wall y+ to judge the result ??? And what length I should use to calculate Reynolds number ? Because the flat plate is perpendicular to flow direction. If the flat plate is parallel to free flow direction, I think wall y+ is applicable and I use the length of flat plate to calculate Reynolds number. Thanks for reading my question. |
formula used for drag force? | kamma | Main CFD Forum | 0 | April 2, 2010 10:21 |
Drag force computation | Martin | Main CFD Forum | 9 | July 11, 2008 09:10 |
How should we calculate the drag force ?? | Thinnapong | FLUENT | 5 | May 4, 2008 13:46 |
How to calculate the drag force? | James | CFX | 1 | April 24, 2008 00:59 |
How calculate drag force for porous sphere | Chandan Sarkar | FLUENT | 2 | September 23, 2002 02:12 |
