Symmetry surface
Old   October 6, 2010, 03:15
Default Symmetry surface
novice
novice is on a distinguished road
Hi All,
I want to simulate a flow through an openchannel to get the headloss values. Should i consider a two phase model or define the freesurface as symmetry surface and simulate a single phase model???
Will there be any difference in the pressure calculations if i consider a symmetry surface in place of the free surface of the open channel.
Thanks in advance
novice is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
