Udf, define_profile, vof
Old   October 24, 2010, 14:05
Question Udf, define_profile, vof
Grzegorz Kondora
kondora is on a distinguished road
Hello all,
Let's assume that we have a Eulerian multiphase simulation. Number of phases is n_phases. For the velocity inlet for each phase we would like to specify volume fraction, which is calculated somewhere within UDF and written to global variable. To do that, we must use DEFINE_PROFILE macro, whose arguments are: DEFINE_PROFILE(vof_profile,t,i), so: name, thread and position/index of variable being set. Let say that we would like to create only one universal function DEFINE_PROFILE, which will be hooked in B.C. panel for each phase other than 1. Here's part of my code:
some code
    #if !RP_HOST /* SERIAL or NODE */
        int ii;
        face_t f;
        Thread *mixture_thread = THREAD_SUPER_THREAD(t);
        Thread **pt;
        pt = THREAD_SUB_THREADS(mixture_thread);
        for(ii = 1; ii < n_phases+1; ii++)
            if(pt[ii] == t)
                Message("\Found it!!!, DOMAIN_PHASE_INDEX is, ii = %d\n", ii);
        begin_f_loop(f,t)
            F_PROFILE(f,t,i) = alpha[ii-1]; /* global array whose elements are calculated in other function
                                                          and having indices according to: ii = PHASE_DOMAIN_INDEX - 1 */
        end_f_loop(f,t)
    #endif /* !RP_HOST */
Can it be easier? I mean - is there any super-hidden macro wich return pointer to the Domain or PHASE_DOMAIN_INDEX, for example:
   Domain *domain = GET_DOMIAN_POINTER_HAVING_GIVEN_PHASE_THREAD(t);
Do you know any other, easier way than I posted? It should be available in FLUENT, esspecialy because people are often using DEFINE_PROFILE macro. Thanks in advance!!!
kondora is offline   Reply With Quote
define_profile, udf, vof
HELP! adding a mass source to VOF eqn. by UDF??? ROOZBEH FLUENT 5 December 3, 2016 17:53
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
HELP! UDF sinusoidal wave, VOF model, porous face! A8anato_psofimi FLUENT 2 November 10, 2009 14:42
UDF to read data from a file for VOF model Pablo FLUENT 0 October 23, 2008 07:02
writing UDF for modelig mass transfer for VOF ardalan soleymani FLUENT 0 July 11, 2007 01:09
