February 28, 2012, 05:44 |
Convergence Criteria in FLUENT
Mahindra
Rep Power: 13 |
Hello everyone
I am new to CFD. I am doing analysis of flow past circular cylinder in ANSYS 13. I created a mesh in ICEM CFD and I am currently doing mesh sensitivity study by refining mesh. I set the convergence criteria to 1e-06 as I am doing laminar flow. I am interested in cd values and I am monitoring cd too. Even after residuals meet convergence criteria, cd value is getting changed. I mean each cd value is repeating twice or thrice and decreasing to next value. If I leave it as such, each value is repeating as many as 10 times. When can I stop? Thank you |
February 29, 2012, 06:58 |
Rep Power: 17 |
If the change in Cd over iterations is higher than the expected variation then try reducing your relaxation factors
Regards Luke |
February 29, 2012, 08:48 |
Rep Power: 14 |
February 29, 2012, 09:55 |
You should observe the value up to fourth decimal place. I usually keep the convergence criteria up to 10e-12 for laminar flows, like you have, so that drag easily converge to required value.
February 29, 2012, 10:51 |
Rep Power: 20 |
CL,CD and CM are global parameters. You should iterate until the drag converges up till third decimal place at least. If there are large oscillations in CD monitor then check your boundary conditions and the quality of your mesh.
Regards |
March 1, 2012, 01:16 |
Mahindra
Rep Power: 13 |
It is not oscillating but decreasing. As I have told, every value is repeating for 7-8 times and then going for next lower value. I mean say from 1.7128 repeating for 8 times and then going to 1.7127 and then repeating again for 8 times and so on.
March 1, 2012, 01:19 |
Mahindra
Rep Power: 13 |
I do not know how to play with relaxation factors. Most of the people recommended not to change factors as they might destabilize the solution. Can you suggest me any changes?
March 1, 2012, 01:22 |
#8 | |
Mahindra
Rep Power: 13 |
Can I assume a converged solution if cd doesnot change over 10-12 iterations? |
March 1, 2012, 01:58 |
#9 | ||
March 1, 2012, 06:46 |
#10 | |
Mahindra
Rep Power: 13 |
Also i have refined mesh 5 folds and it came upto 60 MB of mesh file. Is it normal? And it is taking lot of time fr each iteration. My computer does not have great processing speed. |
What value shall I set for the Convergence criteria? | steventay | CFX | 7 | May 14, 2010 12:44 |
convergence criteria | iuaniu | CFX | 3 | September 24, 2009 19:20 |
Convergence criteria | PrandtlGlawert | FLUENT | 1 | August 13, 2009 18:06 |
Convergence criteria | PrandtlGlawert | Main CFD Forum | 1 | August 13, 2009 17:13 |
Physical convergence criteria | yogui | FLUENT | 0 | April 27, 2005 08:34 |
