static temperature is higher than total temp. in buoyancy problem
Old   October 23, 2010, 06:34
Default static temperature is higher than total temp. in buoyancy problem
amirbahador
amirbahador is on a distinguished road
hi all
I'm simulating fluid flow of molten steel in closed domain using boussinesq approximation because buoyancy is the dominant force in domain ....
problem is solving in steady state mode ....
the problem is that static temperature is higher than total temperature ...for example if total tem. shows 3500k static temp. shows 17000k ....
how can it be possible ?
please help me by your advice to solve it
amirbahador is offline   Reply With Quote
Old   October 23, 2010, 10:42
xrs333
xrs333 is on a distinguished road
Is the solution converged? I 'm afraid it's diverging.
xrs333 is offline   Reply With Quote
Old   October 24, 2010, 07:21
amirbahador
hi dude
the solution is not converging and it is main problem in my work .....I assumed that by finding the solution of decreasing the difference between static and total temprature , diverging problem will be solved ....
if u have any experience in modelling this kind of problems - buoyancy - please help me ....
looking forward your guidance
amir bahador
static temperature and total temperature showwa FLUENT 3 March 24, 2016 05:58
Total and static temperature jak FLUENT 6 April 18, 2007 00:55
total pressure problem Ermanno CFX 5 February 19, 2007 17:16
Total Temperature in a Rotating Frame Paul Lewis CFX 1 September 14, 2005 14:47
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 05:56
