November 14, 2000, 15:28 |
Multiple fluids
I have a heat exchanger system in which hot water exchanges heat with a blowing cold air (ex: radiator). How can I use FLUENT software to consider two seperate moving fluids i.e, two inlets and two outlets.
Thanks |
November 15, 2000, 13:26 |
Re: Multiple fluids
Version 4.x of FLUENT cannot do this, but 5.x can.
November 15, 2000, 13:49 |
Re: Multiple fluids
Is that mean I can have two fluids, with two seperate inlets & outlets in my single model? I already have 5 x
November 17, 2000, 11:01 |
Re: Multiple fluids
you definitely can have more than 1 fluid with more than 1 inlet & outlet.you may try to specify the boundary conditions of your inlet & outlet by using gambit.However,if i'm not mistaken you may only specify a boundary condition to a surface.you cannot specify 2 or more boundary condition to a surface(e.g. you cannot specify velocity inlet & pressure inlet at the same face simultaneously)
Max |
November 4, 2010, 15:40 |
raj
Rep Power: 16 |
Can anyone tell .How to introduce two different fluids with different velocities in FLUENT 12.0 . I have two two inlets and one outlet.
Thank you. |
Display Modes | |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Cross Flow cooling system involving multiple fluids and a solid domain | ajaymenon | CFX | 4 | March 8, 2012 18:00 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
multiple fluids depending on time | seojaho | CFX | 6 | April 13, 2010 16:37 |
Problem of Multiple Fluids | Mehul | CFX | 1 | June 3, 2008 10:31 |
