November 14, 2010, 22:42 |
how to compiled udf ?
zhangzhiyan
Rep Power: 15 |
hi all
i do have no idea about udf, udf1: #include "udf.h" static real v_prev = 0.0; DEFINE_CG_MOTION(piston,dt,vel,omega,time,dtime) { Thread *t; face_t f; real NV_VEC(A); real force, dv; /* reset velocities */ NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); if (!Data_Valid_P()) return; /* get the thread pointer for which this motion is defined */ t = DT_THREAD(dt); /* compute pressure force on body by looping through all faces */ force = 90.0; begin_f_loop(f,t) { F_AREA(A,f,t); force += F_P(f,t) * NV_MAG(A); } end_f_loop(f,t) /* compute change in velocity, i.e., dv = F * dt / mass velocity update using explicit Euler formula */ dv = dtime * force / 50.0; v_prev += dv; Message ("time = %f, x_vel = %f, force = %f\n", time, v_prev, force); /* set x-component of velocity */ vel[0] = v_prev; } it can be compiled like that: but udf 2: #include "udf.h" #include "unsteady.h" #include "memory.h" #include "stdlib.h" #include "stdio.h" DEFINE_CG_MOTION(movewall,dt,vel,omega,time,dtime) { Thread *t; cell_t c; real cx,cy; //CArray<real,real&> vx,vy; int i; int n=0; //if(!Data_Valid_P()) //return; t=DT_THREAD(dt); cx=0; cy=0; begin_c_loop(c,t) { //vx.Add(C_U(c,t)); //vy.Add(C_U(c,t)); cx=cx+C_U(c,t); cy=cy+C_V(c,t); n++; } end_c_loop(c,t); cx=cx/n; cy=cy/n; cx=0; cy=0.05; vel[0]=cx; vel[1]=cy; //Message("\n n=%d, vx=%f, vy=%f\n",n,vel[0],vel[1]); } it can not be compiled : is anyone can help me? thanks.
In learning and straightway practising is there not pleasure also? When friends gather round from afar do we not rejoice? Whom lack of fame cannot vex is not he a gentleman? |
November 15, 2010, 05:55 |
User_CFD
Rep Power: 16 |
I can't see pictures about error:-(
November 19, 2010, 01:53 |
zhangzhiyan
Rep Power: 15 |
thank You lehoang_mai
i have slover that problem
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
I want to use pressure of 1 face in udf that compiled on other face | iman_1844 | Fluent UDF and Scheme Programming | 3 | June 10, 2010 12:55 |
Why udf can not be compiled in my pc? | Xinqiang | FLUENT | 0 | June 10, 2009 14:32 |
difference between udf compiled and udf interprete | chandra sekhar | FLUENT | 2 | April 11, 2006 00:04 |
how to quit compiled or interprited UDF | tian | FLUENT | 0 | April 8, 2003 23:53 |
