May 26, 2008, 11:45 |
surface tension output
Is there any way to read or output the local surface tension? For example, if I have a udf that defines surface tension as a function of temperature, how can I see what value it is from point to point along an interface?
Thanks |
November 19, 2010, 09:09 |
Rep Power: 15 |
i have the same problem
at the moment, i try to write the surface tension value to a .text file (with an UDF) but that also failed please help |
surface tension gradient on a free surface | Abrem | FLUENT | 1 | April 30, 2006 03:41 |
Surface Tension | Jim | Siemens | 0 | October 16, 2002 07:33 |
Surface tension - Continuum Surface Force model | Robert | Main CFD Forum | 0 | May 2, 2002 07:34 |
surface tension in VOF | New1 | FLUENT | 0 | April 10, 2002 01:06 |
[surface tension effect at free-surface ?] | name | Main CFD Forum | 1 | September 21, 2001 09:54 |
