December 3, 2008, 09:41 |
solution initialization
hi,
when initializing the solution, what are the differences if we select all zone & if we select a particular zone for example solid inlet or air inlet. which is the correct approach? thank you. |
December 4, 2008, 00:20 |
Re: solution initialization
Hi Sri,
Intialization is nothing but storing a particular value in all the cells before starting the solution in other words in case of f.v.m. in fluent the value is stored in the cell centriod. the solution can start from zero however can take long time to converge so to reduce it we ask the solver to start from certain value and that is nothing but intialization and then its is always the best way to intialization with ref. to your b.c., Now in many case depending on the physics of the case you can either intialise from all b.c. zones or a particular zone. Rather the best pratice i follow is to intialize from all zones so it gives good stabilization to the solution and can converge at a considerable time... Uday regards |
August 18, 2012, 14:00 |
Initialization doubt
kunar
Rep Power: 14 |
Dear friends,
i am doing steady analysis for my 3D wing model,with velocity is 5m/s. For that i give my Boundary condition ie velocity inlet 1. velocity specification method---->magnitude,normal to boundary 2. reference frame---->absolute 3.velocity magnitude----> 5m/s After this, i go for initialization in that i select, Compute from------>velocity inlet Initial values gauge pressure(pascal)----->o x velocity-------> - 5m/s y velocity-------->0 z velocity---------0 here my doubt is i give velocity is +5m/s in velocity inlet in boundary condition, but i got -5m/s after compute from velocity inlet, what that negative sign indicates? please help me |
Solution initialization | Tim Daly | FLUENT | 1 | January 15, 2009 10:14 |
solution initialization | Jabe | FLUENT | 0 | May 9, 2008 12:42 |
error during solution initialization | Muhammad Usman Qureshi | FLUENT | 7 | March 31, 2008 07:26 |
Conduct initialization with a old mesh solution | Jianfeng Zou | FLUENT | 1 | September 12, 2007 06:06 |
converged solution or correct solution | SAM | FLUENT | 1 | October 12, 2004 15:38 |
