Low temperatures modelling heat pump with source terms
Old   November 26, 2010, 16:43
Default Low temperatures modelling heat pump with source terms
Ian
stahl is on a distinguished road
I am trying to model an air source heat pump acting as a heat sink for a residential building application. As a very simplified model, I created a box shaped fluid zone and adjusted the source terms (not a porous zone). The heat pump has a capacity of approximately 4kW. The pump performs as I expect but in the fluid zone representing the heat pump I get very low localized air temperatures, down to -10C or lower, while the air outside this region is closer to ambient (20C) temperatures.
Just trying to get a sense if this is reasonable or not.
Thanks,
-ian
stahl is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
heat transfer in porous medium (ground source heat pump) nms Phoenics 3 February 16, 2010 04:19
Point implicit treatment of k-e source terms andy Main CFD Forum 5 June 9, 2006 11:03
heat source problem John FLUENT 1 April 9, 2003 13:08
variable heat source simulation LI Y FLUENT 1 April 7, 2003 23:46
