March 31, 2011, 12:40 |
Modelling air flow in a pipe
Chris Cavani
Rep Power: 15 |
I need to calculate the pressure drop of air through a 2m pipe. What would be the best boundary types to use? I would assume the inlet would be 'velocity-inlet' however this means that I am inputing a velocity in the 'boundary conditions' setup and I am also able to input a velocity at the 'initialize' settings. Should I leave one of these as 0? which one?
I am also unsure what is meant by 'flow rate weighting' when I set up the 'outflow' boundary condition. Any help would be appreciated. Thanks. |
March 31, 2011, 15:02 |
xrs333
Rep Power: 16 |
velocity in the initialization settings is for the iteration, and can be set to 0.
"flow rate weighting" is used to allot flow rate when you have more than one outlet. if you have only one outlet, any value of "flow rate weighting" makes same result. but i 'd like to say that if you just want to know the pressure drop, CFD will not always yield result better than conventional formula. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
modelling slug flow with pressure inlet | Azman | FLUENT | 0 | May 29, 2006 06:45 |
HELP!!! Indoor air flow pattern | Peter Zhang | Main CFD Forum | 4 | November 3, 1999 02:49 |
