Floating point exception during parallel mode of fluent |
January 11, 2011, 07:01 |
Aamer Shahzad
Dear all
i am doing simulation on 3 D wing which is having 6.5 million cells. my OS is windows 7 64 bit with 8 gb RAM and 8 cores (i am using 64 bit version of fluent). when i run the case by using 4 cores of the computer (i.e by starting fluent with command fluent 3d -t4) i get error as "primitive error at node 1, node 2 and node 3: floating point exception" after few iterations. As remedial measure i reduced my under relaxation factor and time step but the problem remained the same...... when i run the same case with single processor, the case is running okie under same settings. In order to save the computational time i have to exploit parallelism, i am trying to resolve this issue...... any body having any idea why this error is coming with parallel mode???? |
March 5, 2011, 05:45 |
#2 | |
mohammad
I have a 4-core computer and I want to use Ansys11 on windows7( 64bit)..is it possible? I will be really thankful if you can help me? |
March 5, 2011, 11:43 |
Hello Mohammad and Amir
@Amir : I must say that your error appears because of divergence. Actually what Fluent does is that it divided your comp. domain to all the cores or (nodes) in case of more than one PC. And when divergence appears with minor error the data that is shared b/w the cores also bulges out. This gets handled very easily in case of shared cores in single PC where delay time is negligible b/w cores. May be you get divergence after some more time as compared to distributed parallel. Try to use Density based solver with low CFL at first. * Shared parallel : Same pc and parallelism is between cores ** Distributed parallel : Different (more than one) PC and parallelism between nodes (containing multiple cores) @ Muhammad : Better to check compatibilty on ANSYS website, you should shift to version 12 I think cos ANSYS 11 came prior to Windows 7. |
February 7, 2012, 22:55 |
Floating point error :invalid number
Hello.
I am getting floating point error in my thesis ie the train moving through tunnel. Can any body help me. My email is sheikhnasir39@gmail.com please help me thanks |
September 8, 2012, 00:51 |
#5 | |
Amir Hossein Ahmadi Motlagh
I am now having the same issue getting floating point errors when using SMP with 8 cores. However, things are going well when running with single processor. I was wondering if you had any progress on this issue or anybody else could help me with it. I am modeling an Eulerian-Eulerian gas-solid fluidized bed. The approach proposed by Shamon Jamshed does not work for me as I am not allowed to use density-based solver with MultiPhase models in Fluent. Regards, Amir |
October 30, 2012, 19:14 |
I don't know if this information helps you or not. I was getting the same error. I reduced the relaxation factors as I assumed it was due to divergence. It worked perfect. Btw, I was also running in parallel.
May 8, 2013, 04:47 |
will chen
Rep Power: 12 |
Exactly, I get a convergence result by using your solution. But why this happens?
November 30, 2013, 13:35 |
What parameters should I reduce relaxation factor and until what values?
Thanks in advance |
December 1, 2013, 22:00 |
#9 | |
will chen
Rep Power: 12 |
Regards. |
August 19, 2015, 04:56 |
#10 | ||
Mina
Rep Power: 10 |
I have the same error Could you tell me which relaxation factors? Explicit relaxation factors or Under-relaxation factors ? |
May 16, 2019, 09:49 |
#11 |
Rep Power: 7 |
I also have the same error for viscoelastic flow over a 2D cylinder. I have changed methods, values of relaxation factors and even refined my mesh. but I do not have a solution. can anyone suggest what should I do? for simple laminar flow over the cylinder, it worked well.
reactingFoam floating point exception | pajofego | OpenFOAM | 0 | November 6, 2010 17:29 |
Floating point exception | gareth__it_power | OpenFOAM Running, Solving & CFD | 2 | February 16, 2009 12:55 |
Unable to start fluent in parallel mode | Anand | FLUENT | 1 | January 11, 2009 16:48 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
floating point exception (underflow) | Prashant | Main CFD Forum | 0 | December 17, 2004 01:54 |
