vof and patch
Old   January 11, 2011, 20:38
Default vof and patch
raymond
wlt_1985 is on a distinguished road
I created one volume and patch it with two separate phases with VOF, water at the bottom and air at the top. Then, I would like to have one mass flow inlet of water at the top of the air. The water from mass flow inlet will pass through the air and being added to the water at the bottom. One question here, will the volume of the water at the bottom part being increased due to the addition of water from the mass flow inlet at the top? Since in order to use VOF, it is time-consuming and I am rush in time to know its results. Thanks for help.
Regards
Raymond
wlt_1985 is offline   Reply With Quote
Old   January 14, 2011, 07:57
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Hi
Why you want to set only one mass for water at air inlet? Did you mean that you want to use mixture mass flow rate? If it's so you need to define the mass flowrate at the overall inlet and set the vof for the secondary phase? Furthermore what is the flow pattern it is seem like stratified flow?
kbaker is offline   Reply With Quote
patch volume fraction in VOF at every time step... Marco FLUENT 3 January 1, 2017 12:56
please help to patch volum of secondary phase VOF zidouni FLUENT 1 February 27, 2008 05:46
how to patch a volum of secondary phase using VOF zidouni FLUENT 1 February 26, 2008 02:18
patch volume fraction in VOF at every time step... Marco FLUENT 0 October 8, 2007 05:37
VOF Patch Adour FLUENT 0 April 5, 2007 05:01
