Modelling Slurry flow
Old   January 20, 2011, 18:02
Default Modelling Slurry flow
sunny
sandisk is on a distinguished road
My work is to use mixture model in multiphase flow to simulate slurry flow in straight pipe.The slurry is of water and 0.02476 in. sand particles(5 %). My simulation is not converging. I am not sure which drag functions and other functions to use. Has anyone simulated slurry flow with mixture model ? Please help .. or we should use eulerian model only ?
sandisk is offline   Reply With Quote
Old   January 21, 2011, 12:00
Nikolopoulos Aristeidis
Nikolopoulos is on a distinguished road
Use mixture model is the slip velocity between phases is small and not important.
Use Euler if not.
You are using an unsteady solver?
Nikolopoulos is offline   Reply With Quote
Old   January 21, 2011, 12:15
sunny
The slip velocity between particles is not important, I have unchecked that option. I need to find the pressure drop in the pipe.I am not getting covergence with Euler model too, I tried Schiller naumann drag function and also gidaspow model. I am not sure which options of drag function to select in mixture model. Have you any experience in modelling slurry flow in straight pipes ?
Old   January 21, 2011, 12:17
sunny
I am not using unsteady solver, I am using steady state solver .. Should I use unsteady state ?
Old   January 21, 2011, 12:36
I 'm experienced in Euler - Euler granular flows. I'm working in CERTH/ISFTA in EMMS scheme which is a sub-grid drag model.
I'm not familiar with mixture but i know its limitations.
For sure go to unsteady even if the physics of the problem is steady.
The only way to go steady is with these new pressure-velocity coupling schemes of Fluent 12 but i don't recommend them.
Old   January 21, 2011, 12:44
sunny
Thanks, I had treid the Euler model. But I am not getting convergence,I am not sure where I am going wrong. Can you help me look at my case file, if you can. I am stuck in this problem for last 1 week and I am not going any ahead. If I am able to simulate with Euler model, it will be some progress. Will be really gratefull if you can help me with eulerian model ? pls let me know if it is covenient with you ? Thanks for your help ?
Old   October 28, 2014, 01:23
Ngô Ích Sơn
manowars is on a distinguished road
Dear Nikolopoulos,
I am coding the EMMS global using paper of W. Wang and J. Li (2007). I guess, your EMMS model is EMMS/matrix?
What value of eps_mf? I used 0.4
Can you suggest which value of convergence criteria for hydrodynamics should be suitable? (I am using 1e-3, but it is not converged for eps_g < 0.6)
Can you recommend how many step for each loop? (I am using 20(steps for eps_gc)x20(steps for eps_gf)x1(a_f = -9.8)x100 (for a_c))
Thank you and best regards,
manowars is offline   Reply With Quote
Old   January 18, 2017, 11:28
Prateek Jain
prateekj05 is on a distinguished road
Hi, I'm working on modelling slurry flow through horizontal pipes. I can't converge it. Could anybody help? I've exhausted all my options :'(
Sent from my ONEPLUS A3003 using CFD Online Forum mobile app
prateekj05 is offline   Reply With Quote
Old   January 19, 2017, 09:14
Kushal Puri
Kushal Puri is on a distinguished road
I did thesis on this, you can refer this link
http://dspace.thapar.edu:8080/jspui/handle/10266/2899
Kushal Puri is offline   Reply With Quote
Old   January 19, 2017, 09:19
Kushal Puri
Old   September 11, 2018, 07:41
bhaskar
techbhaskar is on a distinguished road
Dear Kushal,
I looking for modelling of slurry flow, I have found you have work on it. Unfortunately your thesis link is not working. Kindly can you send me your thesis on my personal email id techbhaz@gmail.com.
Regards
Bhaskar
techbhaskar is offline   Reply With Quote
Old   September 11, 2018, 08:47
Kushal Puri
[QUOTE=techbhaskar;706051]Dear Kushal,
Regards
Bhaskar[/QUO
I sent to your mail id
Old   May 6, 2019, 07:28
Aashna Raj
aashna@iitp is on a distinguished road
Sir,
Your link is not working. Can you suggest me any way to view your thesis or if it's not too much, kindly send it to my email id: aashnaraj18@gmail.com
Thanks
aashna@iitp is offline   Reply With Quote
Old   September 23, 2019, 23:51
Post Thseis link not working
  #14
ShreeJeeth
ShreeJeeth is on a distinguished road
Can u send it to my id : iamsj18@gmail.com ?? Or can u update the link?
ShreeJeeth is offline   Reply With Quote
mixture model, multiphase modelling, multiphase pressure drop, slurry flow
Modelling Supersonic TwoPhase Flow with Phase Change wes OpenFOAM Running, Solving & CFD 9 July 27, 2021 11:05
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
modelling blood flow in arteries with starcd sara Siemens 5 April 10, 2007 09:17
Basic Multiphase Flow Modelling krishna Main CFD Forum 2 August 27, 2004 08:40
