January 2, 2016, 05:40 |
How to set periodic conditions
Aja
Rep Power: 14 |
I am simulating an axial turbin. In this turbine, there are two domains.
The first domain is the piping before and after the blade and the second domain contains the turbine blades. The domain containing the blades rotates at 2000 rpm=209.43 rad/s while the other one is stationary. There three pair of rotational periodic faces in numerical model( one is for inlet stationary domain and other one is outlet stationary domain and other one is for rotation domain). In fact, there are three pairs faces parallel to each other. My problem: I validated torque of turbine with experimental values but pressure drop at inlet and outlet of turbine doesn't validate with experimental value correctly. In fact, pressure drop is law and it should be higher. How do i solve this problem? Thanks Aja Last edited by aja1345; January 3, 2016 at 05:38. |
SU2_MSH: Periodic boundary conditions bug | Zef | SU2 | 1 | February 18, 2015 13:28 |
How to set periodic boundaries with initial conditions? | jiandai | OpenFOAM | 6 | October 24, 2013 07:00 |
Problem with Periodic Boundary Conditions Help!!! | otsigun | FLUENT | 0 | July 11, 2013 03:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
multispieces and periodic boundary conditions prob | ydzhang | FLUENT | 4 | May 24, 2001 23:17 |
