turbulent viscosity
Old   January 24, 2011, 08:03
Default turbulent viscosity
EH
ehooi is on a distinguished road
I am solving an unsteady problem and I get the warning message:
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
which appears once at every 10 to 20 time levels. This disappears after some iterations but keeps popping up at new time levels.
My question is, given that this happens only in 1 cell and that the message disappears after further iteration and it only occurs every 10-20 time steps, is it a critical issue?
Thank you.
Cheers,
EH
ehooi is offline   Reply With Quote
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet Felipeb Main CFD Forum 1 July 26, 2010 17:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
