Home > Forums > FLUENT
Storing coefficients with scheme
Old   February 8, 2011, 09:49
Default Storing coefficients with scheme
Paul Levold
Paul_l is on a distinguished road
I've found this thread on how to store residuals using scheme in Fluent which uses the (solver-residuals) function: http://www.cfd-online.com/Forums/flu...ge-fluent.html
However I'd also like to store the lift, drag and moment coefficients (of a airfoil) in the same way. Is there a similar way to get the coefficients using scheme?
Paul_l is offline   Reply With Quote
Old   February 8, 2011, 10:52
DoHander is on a distinguished road
Do you have any particular need for "storing" the coefficients in Scheme ?
Normally you should simply check the Write option in the Force panel and Fluent will write them in files for each iteration.
Do
DoHander is offline   Reply With Quote
Old   February 9, 2011, 08:35
Paul Levold
Sorry, I probably wasn't too clear about what I wanted: I am doing a batch analysis of a steady state problem and I want to store the coefficients found after each run in a text file. I could just use the regular coefficient history which can be written to file, but I'm not really interested in anything but the last result. That's why I'm looking for a way to get the coefficient values into scheme.
Old   February 9, 2011, 09:35
Not a good idea to store just the last value! CL and CD does not converge at the same rate as the residual, so storing the entire history of CL and CD actually makes sense, you can develop a procedure to check if they are converged or you can inspect their history at a later time using a graphical tool.
Do
Thread Tools
Trackbacks are On
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 3 September 30, 2010 10:43
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 10 August 3, 2010 12:23
Expert-param:: Cht diffusion scheme PCFD CFX 4 July 12, 2010 13:49
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 12:08
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 12:21
