August 29, 2002, 03:33 |
backflow volume fraction
I use the multiphase model,in the pressure outlet boundary condition,there is a "backflow volume fraction",i don't understand what's these means,maybe you can help me.Thanks for your help!!!
September 1, 2002, 10:47 |
Re: backflow volume fraction
the backflow vof is used only when there is a reverse flow at the outlet.your convergence would be faster if you give a reasonable value.
September 1, 2002, 20:09 |
thank you very much!another thing is how can get the backflow vof,may through the experiment?
September 2, 2002, 03:40 |
this value has to be intutively.when reverse flow is expected in your domain,then the value has to come from experiments
September 2, 2002, 18:44 |
your help is very useful,thank you very much.
February 19, 2011, 11:53 |
Michael
Rep Power: 15 |
In regards to this.. could the backflow volume fraction be used to restrict the seondary phase from leaving the system at a pressure outlet?
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
