Solution not converging..
Old   February 21, 2011, 15:51
Default Solution not converging..
John
John222 is on a distinguished road
I get an error every time i run this test which says turbulent viscosity is limited to a value, I changed it from the limits to a higher value but i still get the same and my solution doest seem to be good.
John222 is offline   Reply With Quote
Old   February 22, 2011, 09:23
John
???? anyone good?
Old   February 22, 2011, 11:21
Rahul Kumar
rkumar310 is on a distinguished road
Check your boundary conditions for turbulence. Also see where the viscosity is getting limited, that might give you some hint as to where the problem is. In general it is not a good idea to increase the limit. Just run for a few iteration if you see the number of cells in which it is getting limited is reducing just keep running.
rkumar310 is offline   Reply With Quote
Solution not converging Alex FLUENT 5 April 14, 2015 00:55
Solution converged, and then diverge again. jrg FLUENT 2 April 1, 2013 23:10
Unsteady solution Christophe FLUENT 0 August 11, 2006 11:13
Mesh independent solution CFX Begineer CFX 0 October 27, 2002 10:54
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
