boundary conditions for 3D channel flow with heat transfer |
February 21, 2011, 14:14 |
Rep Power: 16 |
Hi user's,
I`m actually simulating a flow in a 3D channel. The dimensions of the channel are 5mm x 0.5mm x 15mm. So it is a very short channel with a lenght of 15mm. The inlet is a mass-flow-inlet, the channel wall is a wall and the outlet is a pressure-outlet (0bar). And the operating pressure is set to 1bar. Now I´m not sure about the correct thermal boundary conditions. The compressible fluid has a temperature of 293.15K at the inlet and the wall get the isothermal temperature of 1273.15K. At the outlet I set the temperature for the pressure-outlet to 293.15K... Is this right? I want to have the average temperature of the fluid at the outlet, but there I say with the boundary conditions that the temperature is 293.15K... It is not a conflict with my target? Furthermore I want to get the heat flow from the wall to the fluid, but this should be ok. Thank you for your help! Regards, Aloex |
February 22, 2011, 12:28 |
Rep Power: 16 |
I solved the problem by my self. For a pressure-outlet boundary condition must define the backflow temperature... So it isn`t the temperature like you have to define at a mass-flow-inlet.
Periodic boundary conditions in 3D Eulerian granular flow simulations | dsm | FLUENT | 4 | March 2, 2012 19:04 |
Open Channel Flow - Setting Boundary Conditions | Christine Sindelar | FLUENT | 6 | June 6, 2011 04:11 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
