how to inject many particles in fluent?
Like Tree1Likes
  • 1 Post By Goutam
Old   February 23, 2011, 10:38
Default how to inject many particles in fluent?
iman vasefi
elah599 is on a distinguished road
I want to inject nano particles in flow and because of small diameter,I have to inject near 2e+15 particles, but fluent doesnt accept more than 2e+9 particles. does anybody know what should I do?
elah599 is offline   Reply With Quote
Old   February 23, 2011, 10:43
Robert
ral007 is on a distinguished road
Are you looking at interaction between each individual nano-particle?...
You could try to aggregate physical particles into 'numerical' particles and examine the solution that way. e.g. each 'numerical' particle represents, say, 1000 or even 1.e+6 physical particles.
ral007 is offline   Reply With Quote
Old   February 23, 2011, 11:03
iman vasefi
no,I just want to investigate the effect of presence of nano particles into heat transfer and flow field. how should I change the physical particles into numerical particles? and it doesnt affect the flow properties?
thanks
Old   February 23, 2011, 16:07
Robert
I think it all depends on how you interpret the injected particles.
For a given particle mass flux, if I decide to inject 10 particles/sec, this determined how any physical particles it represents, provided that all particles are of the same size. If you have different particle sizes, you'd have to know the distribution (i.e. particles as a function of size).
I am also assuming that gasdynamic flowfield is not affected by the presence of particles, and the drag & heat transfer source terms provide means of particles following gas streams. If two-way coupling is needed, there are interaction source terms that you can model.
Old   February 25, 2011, 04:10
iman vasefi
first of all, thanks for your help. all of my particles have a same size. as I found, I have to control the number of particles in flow rate on point properties tab. but I dont know how to implement it. for instance, if I have 1e+9 particles with mass fraction 1% and I want to inject 1000 particles, I have to insert total mass fraction (0.01) in flow rate or I have to divide the number of total particles into injection particles and calculate the mass fraction of them.
Old   February 27, 2011, 02:12
xrs333
xrs333 is on a distinguished road
As stated by Ral007, instead of calculating the kinatic behavior of every particle in the in real world, DPM simulates them with numerical particles, and the number of the numerical particles have to be restricted by the computing resource available.
So, when you define the injection, just specify the particle stream, which is the number of particles every time the injection occurs; and then you should give the mass flow (in the point properties tab of FLUENT DPM panel), which should equals to real flow rate of the particles. In such a way, one numerical particle in the model may represent thousands of physical particles, or just a fraction of it.
xrs333 is offline   Reply With Quote
Old   February 27, 2011, 11:12
Wink
Amir's Avatar
Amir
Amir is on a distinguished road
Originally Posted by xrs333 View Post
hi,
it's true if and only if you had done particle study before. i.e. for example penetration coefficient should be independent of particle streams.
Amir is offline   Reply With Quote
Old   February 28, 2011, 05:57
xrs333
Originally Posted by Amir View Post
hi,
In DPM, the interaction of a numerical particle with the continuous phase depend on the size, shape, mass and velocity. So you have to give right value for these properties. Remember, a particle in DPM is a representative of physical particles with the same properties.
Old   February 28, 2011, 09:07
Amir's Avatar
Amir
I didn't talk about size,shape,mass or velocity !!!
particle study is a very important stage in DPM, here we obtain No. of particle streams that particle properties don't change with increasing streams any more. by this method you can link between realistic and numeric particle streams.
Old   February 28, 2011, 10:33
iman vasefi
as I found, we can have 1000 particles in stream that each of them represents for example 1000 other particles. so I have to consider the mass flow of 1000 particles for each particle in the stream.
Old   February 28, 2011, 15:23
Amir's Avatar
Amir
Hi Iman,
I meant that you should specify No. of streams wisely. e.g. consider a parameter that relate to the particle cloud like penetration coefficient, increase No. of streams until this parameter doesn't change.
Old   March 1, 2011, 04:32
iman vasefi
at first, thanks to all my friends. another question. when I use numerical particle, changing the mass flow is enough or I have to change all properties of starting and end point, such as diameter?
Old   March 1, 2011, 07:42
Amir's Avatar
Amir
you should keep diameter,velocity,... constant. the only parameters you can change are flow rate and stream numbers.
Old   October 8, 2013, 08:43
Default injection
  #14
abhijeet bhagat
abhijeet bhagat is on a distinguished road
can we inject species from 2 point
abhijeet bhagat is offline   Reply With Quote
Old   December 16, 2013, 12:40
Goutam Saha
Goutam is on a distinguished road
I am considering nanoparticle of size diameter = 100 nm = 1e-09 m.
To calculate the total flow rate, I used the formula = density*velocity*area. But when I did the simulation, I didn't find any effect of nanoparticles using DPM.
How to use nanoparticle for DPM?
thakuramit682 likes this.
Goutam is offline   Reply With Quote
Old   March 22, 2016, 05:33
AMIT THAKUR
thakuramit682 is on a distinguished road
hello, did you solve this prolem? i also want to analyse nanofluid with nanoparticle injection.
thakuramit682 is offline   Reply With Quote
Old   April 21, 2017, 05:18
Default DPH in fluent
  #17
sewgolam is on a distinguished road
hallo everone
im new at cfd and i must inject particle in fluent.Wat my condition are:I have a rectangler geomerty where at the inlet i have methane at 1 m/s.I want to inject particle in my model.But do not understant the DPM injection panal even achter reading.How kan help me.
sewgolam is offline   Reply With Quote
Particles are not hitting the wall CedricVH OpenFOAM Bugs 23 May 19, 2016 20:29
Injection of specific number of particles in DPM DH FLUENT 12 March 16, 2016 21:04
Fluent for many particles?? Arturo Ortiz FLUENT 3 June 29, 2010 12:31
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
