how does Fluent calculate the pressure and viscous force ?
Old   February 24, 2011, 10:32
Default how does Fluent calculate the pressure and viscous force ?
esi nikki
e30.lsb is on a distinguished road
can someone explain me, how does Fluent calculate the pressure and viscous force ?
In the handbook in section "29.3.1 Computing Forces, Moments, and the Center of Pressure" it is only described, that the total force component is computed using the pressure and viscous force vector.
But, hoe are they calculated?? I didn't found anything about that in the manual...
Thank you!
ESI
e30.lsb is offline   Reply With Quote
Old   February 25, 2011, 03:23
lalupp
lalupp is on a distinguished road
I think pressure drag = Fx = ∑pA.nx and summation is done over the number of wall faces
For estimating viscous drag stress tensor is needed which is a function of strain tensor obtained by appropriate viscous assumption
lalupp is offline   Reply With Quote
Old   March 7, 2011, 20:44
J.-H. Wang
f0208secretx is on a distinguished road
@lalupp:
Since you've mentioned, I'm wondering if there are direct ways to output the force and moment during the transient calculation. Let's say per time step for example. It seems to me that we could only use thoses options in "monitor" panel and yet it is restricted to Cl, Cd and Mx only. If you have any thoughts for that please help me out...
f0208secretx is offline   Reply With Quote
Old   April 9, 2011, 13:23
Default @ JH, Wang
Ugly Kid Joe
vmlxb6 is on a distinguished road
Did you find out a direct way to output the forces on a body wrt time ????????
All I can do using FLUENT is to get Cl and Cd using Reference values. Also if the reference values have length & depth then why is there area mentioned. In calculating the Cl or Cd what does FLUENT take into account, length and depth or the ARea ?????
Thank you.
vmlxb6 is offline   Reply With Quote
Old   April 10, 2011, 21:23
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Thank you.
to have the forces, you have to go to results-->reports---> forces.
from there you can set that you are displayed on the console or grouped in a file. they will come splitted between viscous and pressure. you can avarage them in time, fft'em, everything.
sail is offline   Reply With Quote
Old   April 10, 2011, 22:07
Ugly Kid Joe
Reporting the forces displays the force (viscous+pr.) at a particular time.
How do I get a plot of the forces vs time. Like how we have it for Cl vs time or Cd vs time.
Thank you.
Old   April 11, 2011, 11:00
J.-H. Wang
Dear,
Please search my post in this forum. I have answered myself in a series of discussion.
JH Wang
Old   June 27, 2011, 21:31
Tobino
tobino is on a distinguished road
I am not clearly about Pressure Resistance, Viscous resistance and total resistance reporting by Fluent. So, In Fluent Total resistance = Viscous R + Pressure R but flowing theory of resistance Viscous R = Pressure R + Frictional R.
What is mean Viscous R and Total resistance in Fluent ?
Thanks,
tobino is offline   Reply With Quote
force
Viscous force and coefficient viscous force tobino Main CFD Forum 0 February 20, 2011 21:06
problem with pressure force report jvd FLUENT 0 August 3, 2010 02:19
how does Fluent calculate the pressure and viscous force vector? Ralf Schmidt FLUENT 2 May 17, 2010 15:49
pressure force and viscous force CFD FLUENT 0 March 7, 2006 01:03
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
