Natural Convection of air
Hi there I hope someone can help me. I am modeling natural convection of air in a large rectangular cavity and the results from my previous simulations are not accurate enough. I have simulated the problem using boussinesq, I have used turbulence models (Standard K-Epsilon and RNG), now I would like to use varying properties of air. I want to vary the properties of air according to a polynomial function, but as soon as the density is changed to a polynomial f(T) then the simulation will not converge.
Any help or suggestions will be much appreciated. Thanks |
Natural convection of air
What I am basically doing is testing different models in Fluent to try and get the most accurate results. The results from Fluent I then compare to experimental results. My previous results are previous models I have developed and what I am acctually saying is that with the varying properties of air I am unable to find any convergence. I have used the boussinesq approximation but my temperture differences are quite high so another test would to model the air as an ideal gas, but also as some f(T). That is why I want to try and model the air with varying properties. All the properties of air is defiened as a 2nd order polynomial function that is dependant on the temperture.
ro=353/T |
Thanks for the reply, I will be modelling air as an ideal gas and see what effect that has on the results.
Thanks I will try that as well.
