Loading parallel udf
Old   May 5, 2006, 17:59
Default Loading parallel udf
Pablo
I got some problems loading a parallel udf. When I try to compile the udf, averything works well, but , when I load it I got this error:
************************************************** ********** Primitive Error at Node 0: open_udf_library: No such file or directory connect to address 152.74.25.116: Connection refused connect to address 152.74.25.117: connect to address 152.74.25.116: Connection refused trying normal rsh (/usr/bin/rsh) Connection refused connect to address 152.74.25.118: Connection refused connect to address 152.74.25.117: Connection refused trying normal rsh (/usr/bin/rsh) connect to address 152.74.25.118: Connection refused trying normal rsh (/usr/bin/rsh)
Primitive Error at Node 3: open_udf_library: No such file or directory ************************************************** ***********
We've changed the fluent's scrip file changing rsh by ssh, and rcp by scp because we want to use only ssh as a communicator.
When we run a case without udf's ,our linux cluster works well, but , when we try to run a case that has to use udf's it doesn't work.
bye, thanks in advance.
Old   May 5, 2006, 18:34
Default Re: Loading parallel udf
Benzamia
check the linker udf c++
Old   May 5, 2006, 22:32
whpsoft
please add \\computername/libudf_directory in your libudf directory. in addition, you must share your libudf_directory to all cluster computers.
wish to have some help for your problem!
Old   May 6, 2006, 11:59
pablo cornejo
thanks,
I already fixed it. Now it works. The key thing was with the environmental variables. if anyone needs some information related, just let me know
Old   August 16, 2010, 02:52
Default same error loading udf
jvd
javad
jvd is on a distinguished road
Hi pablo cornejo
I already ran in to a same problem. the udf compile well but it ran in to the same error when I load it. what did you do exactly about the environmental variables?
thanks anyway.
jvd is offline   Reply With Quote
Old   March 1, 2011, 10:32
Red face same problem
Chao Li
LICH is on a distinguished road
Hi!
I'm try to running a parallel fluent on a LINUX Cluster.
My case contained a UDF about DPM. It can be compiled successfully without any Error. But when I loaded it, the same problem occured:
Primitive Error at Node 0: open_udf_library: No such file or directory.
Primitive Error at Node 1: open_udf_library: No such file or directory.
Someone said there was something wrong about Enviroment Varibles. So I launched fluent with parameter -env. But I just don't know how to check the problem. Anybody knows details about this? or solved this problem?
I found many people had the same question with me. but no conclusion.
THANKS A LOT IN ADVANCE!! lich
LICH is offline   Reply With Quote
Old   March 2, 2011, 00:38
Chao Li
Great! It works.
Just change the path of directory "libudf" into absolutely path like "/home/.../libudf" when you compiling and loading the source file.
THANKS!
Old   March 6, 2011, 10:25
Faraj
Filankes is on a distinguished road
Pablo I have the same problem, please help me!
Filankes is offline   Reply With Quote
UDF parallel Lucy Fluent UDF and Scheme Programming 3 May 28, 2013 13:14
Face handling in Parallel UDF O.D.Y. Fluent UDF and Scheme Programming 0 May 1, 2009 06:10
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 11:19
parallel UDF problem kerem FLUENT 2 June 20, 2006 06:56
UDF in parallel version of fluent yobee FLUENT 2 August 5, 2004 00:36
