Nusselt number variation over a ribbed surface
Old   March 8, 2011, 14:48
Default Nusselt number variation over a ribbed surface
Avinash
avi031 is on a distinguished road
I am Avinash. I am working on "Heat transfer analysis in a turbine blade cooling passage of trapezoidal crossection"
Boundary conditions:
Inlet-Mass flow
Outlet-Pressure outlet
Two opposite surfaces of the passage are given constant heat flux and are of the same value. The surfaces have 45 degree ribs to enhance heat transfer coefficients.
Problem: I need to obtain the variation of nusselt number over the heated surfaces..therefore a central line was drawn over each of the surface and the surface nusselt number was plotted.....but unfortunately i am not getting realistic values of the nusselt number......lot of difference between the expt and cfd values. Convergence criteria was met. Realizable k-epsilon model was used. Can somebody pls provide suggestions in getting the suitable values of the nusselt number???
Regards
Avinash
avi031 is offline   Reply With Quote
Old   March 9, 2011, 11:57
Yogesh Patil
foamcfd is on a distinguished road
What is the value of y+. For your kind of analysis it should be less than 1. Also try using k-omega SST instead of K-epsilon.
Regards,
yogesh
foamcfd is offline   Reply With Quote
Old   March 10, 2011, 12:09
Avinash
@yogesh
my y+ value is 3.7...........i will use the sst k-omega model and see if i can get accurate values..your reply has been helpful....thank you very much
Airfoil Average Nusselt Number calculation y2k_o__o FLUENT 6 March 3, 2011 07:37
Local Nusselt Number rohangulavani FLUENT 0 July 6, 2010 07:03
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Nusselt Number abir FLUENT 1 August 30, 2009 03:48
how to calculate Nusselt number? prayskyer Main CFD Forum 0 June 17, 2006 20:57
