Is it possible to hook two UDFs?
Old   March 23, 2011, 18:06
Exclamation Is it possible to hook two UDFs?
giovanni ingrassia
giov_ingr is on a distinguished road
Hello
I am working with a 2D microeolic system. I am setting 6DOF simulation configuration.
After a lot of work i arrived at this point:
  • I set the smoothing and remeshing options properly;
  • I hooked the DEFINE_6DOF_PROPERTIES with mass and inertial moments properly to the rigid body;
The problem is that, when i start the mesh motion, the wings start to move horizontally, instead of rotate, creating a negative volume.
I know that the problem is related to the CG properties, so i wrote the DEFINE CG MOTION UDF but i cannot hook two UDFs together for the same body.
What should i do to set these properties together?
There are other methods to solve the problem?
Thank you for your attention
giov_ingr is offline   Reply With Quote
6dof, dynamic mesh, fluent, udfs
problem using property udfs in parallel mode EllenW Fluent UDF and Scheme Programming 5 July 10, 2009 04:31
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 17:18
Unsteady and Flux UDFs for UDSs tom FLUENT 0 February 13, 2009 10:27
Multiple UDFs Graeme FLUENT 4 August 28, 2004 15:47
Experimental Repository for UDFs, Journal Files and Scheme Scripts Jonas Larsson FLUENT 0 March 5, 2000 15:36
