Bulk temperature Tf is obtained from total or static temperature? |
March 30, 2011, 05:56 |
Hi, how are you? I have a question for your help.
Assume compressible idea-gas coolant flows into heated channel like turbine blade internal channel. BC: walls are given constant heat flux, inlet is given mass flow and total temperature, outlet is given pressure. Now I want to obtain the heat transfer coefficient, h=q/(Tw-Tf). Generally the bulk temperature,Tf, is simply averaged by inlet and outlet temperature. Now, I just want to know, do the inlet and outlet temperature be referred to total temperature or static temperature? Or, Tf is averaged by inlet static temperature and outlet total temperature ? Wall temperature,Tw refer to static temperature? If I choose static, the some of Tw are lower than the Tf. Please help me charify the problems. Thank you. |
static temperature and total temperature | showwa | FLUENT | 3 | March 24, 2016 05:58 |
static temperature is higher than total temp. in buoyancy problem | amirbahador | FLUENT | 2 | October 24, 2010 07:21 |
Total temperature and static temperature | rogbrito | CFX | 1 | June 21, 2009 18:37 |
Static and Total Temperature | Tomislav | FLUENT | 4 | December 4, 2006 04:59 |
The static temperature is higher than total temp | devy | FLUENT | 0 | March 27, 2003 20:16 |
