Number of iterations
Old   April 5, 2011, 15:02
Unhappy Number of iterations
Norasikin Mat Isa
Nora is on a distinguished road
Send a message via Yahoo to Nora
Dear All,
I'm working with a 3D model, a cylinder with tangential air inlet. I've meshed the model for 3 million cells. When I run the simulation, the number of iterations only arround 400 - 500 iterations to get a convergence. Is it possible something like this happen or there is a problem with my model?
Please help.
Thanks
Nora is offline   Reply With Quote
Old   April 6, 2011, 03:04
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
in solve/monitor/convergence...
disable the check convergence, and let iterate.
Consider a convergence history (monitoring) of your goal quantity (massflow at inlet, pressure at inlet or whatever)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 6, 2011, 06:07
Norasikin Mat Isa
Thank you for your reply. How disable the check convergence make any different? Sorry I still don't understand. Please explain more, thanks.
Old   April 6, 2011, 06:14
-mAx-'s Avatar
Maxime Perelli
For instance if you want to compute the drop pressure in a valve (steady state): your residuals are falling down (converging), but if the monitoring of pressure at your inlet is still oscillating, then you don't have a converged solution (although all your residuals are below teh target you specified).
Old   April 6, 2011, 06:52
Norasikin Mat Isa
Hi, thank you very much for your help. I think I understand now what do you mean by diasble the check convergence, and let it iterate. But how do I know when to stop? Or should I make the absolute criteria smaller, let say 10 to the -6? And one more question, how to the monitor the pressure at the inlet? Thanks again.
Old   April 6, 2011, 06:58
-mAx-'s Avatar
Maxime Perelli
you can monitor with surface/monitor...
And to stop, a nice CTRL-C will do it perfectly
Old   April 6, 2011, 07:00
taff224 is on a distinguished road
The definition of convergence can vary.
If the residuals have flattened off and are not changing over time then more iterations are not worth doing, you will not get any better convergence. Whether this is an acceptable level of convergence is a different matter.
The easiest measure of convergence is to get all the values of mass flux for the solution - then work out the difference between input and output. If this is less than 1% of the smallest individual input/output stream then you are probably at a sensible level of convergence.
Remember convergence doesn't mean correct, it just means the calculation has gone as far as it can with the setup you have.
taff224 is offline   Reply With Quote
Old   April 6, 2011, 07:05
Norasikin Mat Isa
Thank you very much for all replies. Its really help.
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 10:54
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 10:47
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
