radial turbine blade simulation with dynamic mesh 6dof(fluent) |
April 7, 2011, 14:28 |
#1 | |
mamadreza
Rep Power: 15 |
help,help,help...............
Hi i want to solve flow in a radial turbine wheel(with high RPM). Because the flow work is done on the blades to make the blades rotating,I decided to use dynamics mesh with 6dof. First, I'm not sure about my udf file, which is written bellow: Quote:
(z axis is the axis of rotation) Please tell me is it coorect? Also because of memory limitation, I devide the turbine wheel geometry in similar sections and read one of them using periodic boundaries. can I simulate the flow in this manner? and if it is possible, which kind of zone (Rigid Body/Stationary) is defined for periodic zones? Thank you. Kind regards, mamadreza. |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
how to obtain mesh file of cooled turbine blade | rajesh kumar gupta | FLUENT | 0 | October 18, 2007 04:18 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
