AXIAL TURBINE 1000 kW RSF C P in 3,0 bar
Old   April 14, 2011, 10:02
Default AXIAL TURBINE 1000 kW RSF C P in 3,0 bar
septianta yochi
doklat is on a distinguished road
hi everyone,
i'm a new member here.
i'm working on my thesis about axial turbine.i've tried to simulate it with sliding mesh that shown in tutorial 11 at fluent tutorial guide. but the result isn't exactly match with my calculation.anyone can help me to evaluate my work?
thanks,
best regards,
ian
*here i append my work http://www.ziddu.com/download/145981...iasi1.rar.html
doklat is offline   Reply With Quote
Old   April 15, 2011, 00:29
septianta yochi
my simulation is in 2D
i'm using steady state then i continue into transient..
Solver : density based - explisit - unsteady - 2nd order Implicit (the other is default)
Viscous model : k-epsilon (default)
Material : user defined ( parameters are based on 3 bar water vapor with ideal-gas density)
Operating Pressure : 0
Boundary Conditions :
  1. inlet stator : pressure inlet : 300000 pascal - turbulent intensity 3.6 % - hydraulic diameter 0.01898 m - temperature 469.4314 K
  2. interface stator
  3. interface rotor
  4. outlet stator : pressure outlet : 128567 pascal - turbulent intensity 3.48 % - hydraulic diameter 0.01898 m - temperature 406.0244 K
  5. fluid rotor : Moving mesh - y velocity 68.3296 m/s
Solution Controls :
  1. relax factor : default
  2. courant number 1 - multigrid levels 5
  3. discret : second order
Old   April 15, 2011, 00:42
septianta yochi
in my calculation the mass flow rate is about 3.5 kg/s, with 72 blades its mean that the mass flow is around 0.048611 kg/s each blade..
but the result in fluent is 1.8 kg/s..
does it mean that i have to use 3D simulation?
Axial Flow Turbine Problem Manish FLUENT 1 February 14, 2017 03:46
Sliding mesh vs MRF in axial turbine simulation Vito FLUENT 3 December 21, 2011 04:57
Axial Thrust in a Radial Turbine Amit Roghs CFX 3 May 31, 2010 16:47
simulation Axial flow turbine using CFX dia aisa CFX 3 May 2, 2008 02:45
Axial flow turbine approperiate B.C dia aisa CFX 0 April 30, 2008 03:32
