UDF Access violation
Old   April 15, 2011, 17:31
Default UDF Access violation
John
therandomestname is on a distinguished road
Hello all:
This is my first time using UDFs. I wrote a UDF for a volumetric reaction rate. It compiles, but gives me an access violation every time I try to run the simulation with it hooked in. It is pretty basic, the only tricky thing about it is that the rate formula uses the mole fraction, X, rather than the mass fraction. Does an access violation mean that there is a problem with the way the UDF is written or could it be a computer problem?
Here is the code:
#include"udf.h"
DEFINE_VR_RATE(co_combust,c,t,r,mw,yi,rr,rr_t)
real mw_mix = 0;
real yx = 0;
real mwx = 0;
real xfuel = 0;
real xo2 = 0;
real mole_con_fuel = 0;
real mole_con_o2 = 0;
int i = 0;
real *rate = 0;
for (i = 0; i < r->n_reactants; i++)
yx = yi[r->reactant[i]];
mwx = mw[r->reactant[i]];
mw_mix = mw_mix + yx * mwx;
xfuel = yi[r->reactant[0]]*mw_mix / mw[r->reactant[0]];
xo2 = yi[r->reactant[1]]*mw_mix / mw[r->reactant[1]];
mole_con_fuel = xfuel * C_P(c,t) / (UNIVERSAL_GAS_CONSTANT * C_T((c,t));
mole_con_o2 = xo2 * C_P(c,t) / (UNIVERSAL_GAS_CONSTANT * C_T(c,t));
*rate = -59.8 * pow(C_P(c,t), 0.3) * C_T(c,t) * mw[r->reactant[0]] * pow(xfuel, 0.5) * xo2 * exp( -12200 / C_T(c,t));
therandomestname is offline   Reply With Quote
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 07:29
udf error : access violation butterfly007 Fluent UDF and Scheme Programming 2 June 1, 2012 11:01
UDF problem (ACCESS VIOLATION) Jorge Poyatos FLUENT 5 March 16, 2009 08:02
Urgent! Access violation of UDF using VOF Rucy FLUENT 0 January 9, 2006 04:01
Error (ACCESS VIOLATION) with UDF Ale FLUENT 2 May 28, 2002 02:50
