Rotor-stator compressor Stage!! Plz Help!
Old   April 17, 2011, 20:34
Default Rotor-stator compressor Stage!! Plz Help!
Billy
Xazopaido is on a distinguished road
Hey Guys!
First of, I would like to say congats to your site! Very helpful and keep up the excellent work!
So, I have basically designed a transonic compressor stage. A row of rotor and a row of stator. I have already have the 3D model and created the mesh and now I am stack in the setup section of Fluent.
I would like to model a compressible flow going into the compressor stage. THe result I want to get is an increase in pressure in the stator outlet. I should menthion that I used the mixing plane function of fluent and my model is ready for simulation. I run some simulations using pressure based solver with the air dencity constant and I got pretty good results (in my opinion) (I mean that I got the pressure rise I want and the temperature rise that I want).
The thing is when I change the density from constant to ideal gas I get
messages like Divergence in AMG solver and float point exception! And the simulation stops. I would like to use compressible flow because that would give me more realizable results. And also with compressible flow I can see Mach number contours in the rotor tip which I am intersted in as well.
What do you think it is the problem? Sorry for the looooooooong post!! I'd really appreciate any help! Thanx in advance!
Xazopaido is offline   Reply With Quote
I need a guideline for FLUENT!! plz.. ruzfactor FLUENT 2 November 19, 2010 12:06
plz help me! saha2122 FLUENT 4 September 21, 2010 07:17
plz help its urgent garima chaudhary FLUENT 0 September 25, 2007 05:28
plz help again! sameera Main CFD Forum 9 August 16, 2007 08:54
plz ......help me out.....************************ krishna FLUENT 2 January 10, 2007 02:53
