Drawing Contours without showing mesh
I would like to know if it is possible for me to draw contours in FLUENT while the mesh does not show
Thank you |
draw grid
you can disable the draw grid in display panel in fluent
2 Attachment(s)
thank you for your reply. Yes, it works, but when I have drawn my contour or vector and remove the mesh it shows an empty box.
Can you please give me the exact procedure to draw a contour without the mesh showing. what I clicked; Display > Mesh > Display I have attached the pictures to show what I mean |
diplay/contour
I do this work and do not have this problem...
please explain |
display/contours/temperature or velocity oir whatever
and desable "Draw grid" |
your case is 2d, so you should not select any surface to display contour.
I send two picture for you. see these pictures and follow them.http://d/cfd%20c/6.GIFhttp://www.cfd-online.com/Forums/D:%5Ccfd%20c%5C1.bmp http://www.cfd-online.com/Forums/D:%5Ccfd%20c%5C2.bmp |
Thanks for your reply, could you please post the pictures again because I cant find them
1 Attachment(s)
mojtaba1365 and ioc,
I did uncheck the draw mesh box, but it still displays the mesh. Check it in this pdf I would attach |
I got it.
follow this: display-contour-do not select any surface in surface panel- select Filed. you have selected all the surfaces, but you should not do this work be my guest buddy... |
Brilliant. Thank you, that works. Do you know if/how I can apply law of the wall in FLUENT.
please explain...
I was asked to apply law of the wall http://en.wikipedia.org/wiki/Law_of_the_wall to my cylinder wall, dont know whether FLUENT does this.
you can run your case and then compare your results with the law of the wall formula...
