XY plot into excel
I'm trying to find a way to import raw data from XY plot in Fluent into excel. Is there any way to do this?
regards, |
I've found it by manually opening .xy file into notepad then copy to excel. Thank you for your attention.
you can easily do this two ways:
1. use file - export - ascii then you select the surface/region/or line you want data from and the data you want. Then hit save. You now how a file you can open and copy and paste into excel. 2. use the TUI to export the data: plot plot yes filename.txt no no no phase/property yes 1 0 surface# |
