Diffusion simulation
Old   April 29, 2011, 11:01
Default Diffusion simulation
Momomanabo is on a distinguished road
Hi all,
I want to simulate diffusion in a 2D geometry. The geometry is a simple circle with a diameter of 500µm. I want to put water in it and then simulate a tracer (which is also water, but with another color), which I patch with a diameter of 50µm, which will move to the walls. That way I can see how long it takes before it reaches the walls and then I can calculate diffusion and see whether fluent simulates it right.
The problem is the geometry. When I define the outeredge of the circle as a pressure outlet and when I patch the tracer in the middle and start the simulation, it won't move at all. So I think I need some kind of entry (maybe a velocity-inlet) in the middle, but I'm not sure, because when I give the entry a velocity then it will influence the diffusion.
So anyone knows how to solve this problem?
Grtz
Momo
Momomanabo is offline   Reply With Quote
fluent in diffusion simulation appleyy FLUENT 4 September 16, 2017 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
Time unit in finite volume solution for diffusion problem. alpha2beta Main CFD Forum 0 June 30, 2010 02:05
