May 2, 2011, 00:58 |
[help Beginner]calculation error
Jang Mingi
the followings are the error messages I got
global courant number is greater than 250.00 the velocity field is probably diverging. Please check the solution and reduce the time-step if necessary. i'm trying to solve two-phase flow inside a cylinderical tank which has water jet inlet. i've tried several models but i got the same message. FLUENT cannot calculate even one iteration. help me. |
May 3, 2011, 09:56 |
you need to provide more details of your case, steady/transient? vof? explicit? what time step? greetings |
May 4, 2011, 16:41 |
I know this is obvious, but did you try reducing the time step? it will converge slower but it should be more stable.
courant number, diverging, fluent, two-phase flow |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
