2D NACA0015 aerodynamic coefficients computimg
Old   May 3, 2011, 01:25
Question 2D NACA0015 aerodynamic coefficients computimg
qingkai
sailor is on a distinguished road
I'm fresh in Fluent. I have an easy question here.
I want to get the aerodynamic coefficients of NACA0015 airfoil. But the results do not match with the data of others.
So I need some help about the set in Fluent, such as choose Laminar or Spalart-Allmaras?steady or unsteady?
Thanks in advance!
sailor is offline   Reply With Quote
Old   May 3, 2011, 12:58
xaero is on a distinguished road
normally, I'd say this is a steady case. You have to decide whether this is laminar or turbulent by calculating the Re-number...
Also be sure that your calculation area (especially behind the airfoil) is long enough and the wall y+ is acceptable. Furthermore, cell refinement at the gradients (of pressure e.g.) should be set up.
There's a tutorial at https://confluence.cornell.edu/displ...+Specification check it out!
xaero is offline   Reply With Quote
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 11:26
2D NACA0015 aerodynamic coefficients computimg sailor Main CFD Forum 0 April 29, 2011 08:29
How to calculate viscous part of aerodynamic coefficients in 3D NS-flow hmd Main CFD Forum 1 October 15, 2010 07:27
Computing aerodynamic coefficients on bidimensional sections in 3D problems Aragon FLUENT 0 July 22, 2009 04:07
Launch vehicle aerodynamic coefficients B. Sulejmanovic Main CFD Forum 1 April 26, 2005 09:59
