[Sponsors] | |||||
tirtha
Rep Power: 16 ![]() |
im trying to simulate mixing in a cylindrical tank with constant volume of two liquids(which im trying to mix) with one inlet at top and one outlet at the bottom,, and in actual case i have to pump the output and feed it as the inlet (recirculation).
how can i define the concentrations of outlet to the inlet directly without manually changing the values after each iterations. is there any way i can hook the outlet data with an inlet data directly..... hoping for a reply,,,,,,,,,,,,,,,,,,,,,,,, tirtha |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3D mixing tank using MRF/SRF | cfd_confuse | Main CFD Forum | 1 | September 13, 2016 03:43 |
| Meshing industrial scale mixing tank | mlbontbs87 | FLUENT | 0 | April 26, 2011 16:18 |
| Agitator Mixing Tank | Mudblood | FLUENT | 1 | November 12, 2010 15:39 |
| 3D mixing tank using MRF/SRF | cfd_confuse | FLUENT | 0 | October 2, 2010 04:46 |
| Mass conservation problem in mixing tank multiphase simulation | rockewan | FLUENT | 0 | April 6, 2010 13:34 |
