How to calculate the wall temperature
Old   January 4, 2012, 04:42
Question How to calculate the wall temperature
mali28 is on a distinguished road
I have a cylindrical geometry with fluid flowing inside. I have specified a constant wall heat flux boundary condition at the wall, so that a constant heat is lost per unit area from the walls. I want to calculate the wall temperature. For that I will need to know the inside film coefficient.
Can anyone suggest a way to calculate the inside film coefficient in Fluent?
Thank you.
mali28 is offline   Reply With Quote
Old   January 14, 2012, 20:59
Real Name :)
ComputerGuy is on a distinguished road
Are you trying not to perform a conjugate heat transfer problem? Meaning, are you trying not to allow fluent to calculate the interfacial heat transfer for you? Generally, for a cylindrical geometry (a pipe) with fluid flow on the inside, the heat transfer between the fluid and wall are coupled, and Fluent calculates this. If you're simply trying to calculate heat flow through a cylindrical wall, there are correlations for inner heat transfer in single-phase flows which do a good job. Go here: Internal Flow Heat Transfer Correlations for a good summary. If you don't want to go to the link, Google "Gnielinski correlation."
ComputerGuy
Thank you.
ComputerGuy is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
How to input the wall temperature b.c.? Jimmy Siemens 9 March 14, 2008 09:31
Variable temperature wall boundary condition Virginie FLUENT 2 October 2, 2007 09:23
Deformation of wall by temperature condition Jay FLUENT 0 April 14, 2007 18:06
Calculate incoming temperature to a wall Javier PĂ©rez FLUENT 0 April 25, 2006 08:30
