Need help creating geometery
Hi all,
I am currently working on the fluid mechanics project. The project is about to calculate the hydroplanning forces on the moving wheel of the car. I have to work with multiphase flow (Air + water). The schematic view of the problem is attacged The Bounday Conditions are 1-Air and water both are moving with the same speed. 2-The tire is rotating and moving at the same time. 3.Ground and walls are moving. Please tell me how can i use Split command to split the box in two segments. I am using ANSYS 13 for that. Apprecite your suggestion |
