Fluent jobs through pbs
Old   March 10, 2010, 14:39
Default Fluent jobs through pbs
Ibad Kureshi
ibnkureshi is on a distinguished road
Hi all,
I am a system admin at a UK university and we got a request to provide an HPC resource for fluent.
After installing Fluent on Our Cluster which is running CENTOS5.4 and is of the architecture nodes=16pn=4 plus a head node we were successfully able to start fluent vi the terminal and submit parallel jobs through the shell with a journal file and the -g switch. The University has 45 licenses for Fluent 6.3.26 and 30 licenses for an older version 6.0/2?? (not sure which). These licenses reside on a windows server with flexlm running on it. We have floating licenses for many softwares on that machine.
When I try to submit a job through the job scheduler PBS the simulations do not run as there is a license problem, even though it seems to be looking in the right place.
I have posted this on a PBS/TORQUE based forum as well but I thought since it dealt with fluent users here might be better help.
I would appreciate any help regarding this. Below are the PBS submission script, the journal file, the PBS output file and the PBS error file respectively.
______________________________
PBS Submission Script
#!/bin/bash
# Example PBS script to run a job on the myrinet-3 cluster.
# The lines beginning #PBS set various queuing parameters.
#PBS -m e
# o -N Job Name
#PBS -N fluent
#PBS -M sengik@hud.ac.uk
# o -l resource lists that control where job goes
# here we ask for 3 nodes, each with the attribute "p4".
#PBS -l nodes=3
# o Where to write output
# asd PBS -e stderr
# asd PBS -o stdout
# o Export all my environment variables to the job
#PBS -V
fluent 2d -g -ssh -t3 -i /home/sengik/Desktop/test/input.in
Journal File
file/read-case /home/sengik/Desktop/test/2dcar_10.cas
solve/initialize/initialize-flow
file/write-data /home/sengik/Desktop/test/2dcar_10.dat
exit
yes
#as you can see just a simple case of load initialise save and exit
PBS Output File
/usr/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 2d -g -ssh -t3 -i /home/sengik/Desktop/test/input.in
Loading "/usr/Fluent.Inc/fluent6.3.26/lib/fluent.dmp.114-32"
Done.
/usr/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 2d -pethernet -host -alnx86 -t3 -mpi=hp -path/usr/Fluent.Inc -ssh -cx node16.testbed-CLS:56711:56126
Server node is down or not responding
See the system adminstrator about starting the server, or
make sure the you're referring to the right host (see LM_LICENSE_FILE)
Feature: fluent
Hostname: mech1
License path: 7241@mech1:/usr/Fluent.Inc/license/lnx86/../license.dat
FLEXlm error: -96,7. System Error: 11 "Resource temporarily unavailable"
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
PBS Error File
/usr/Fluent.Inc/fluent6.3.26/bin/fluent: line 2397: glxinfo: command not found
/usr/Fluent.Inc/fluent6.3.26/cortex/lnx86/cortex.3.7.3 -f fluent -g -i /home/sengik/Desktop/test/input.in (fluent "2d -pethernet -host -alnx86 -r6.3.26 -t3 -mpi=hp -path/usr/Fluent.Inc -ssh")
Starting /usr/Fluent.Inc/fluent6.3.26/lnx86/2d_host/fluent.6.3.26 host -cx node16.testbed-CLS:56711:56126 "(list (rpsetvar (QUOTE parallel/function) "fluent 2d -node -alnx86 -r6.3.26 -t3 -pethernet -mpi=hp -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "3") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/usr/Fluent.Inc") (rpsetvar (QUOTE parallel/hostsfile) "") )"
Welcome to Fluent 6.3.26
Copyright 2006 Fluent Inc.
All Rights Reserved
Loading "/usr/Fluent.Inc/fluent6.3.26/lib/flprim.dmp.1119-32"
Done.
Unexpected license problem; exiting.
______________________________________
The simple line:
fluent 2d -g -ssh -t3 -cnf=<hostfile> -i /home/sengik/Desktop/test/input.in
works perfectly fine.
EDIT: PBS allocates the nodes correctly and is working fine. the simulation just ends when the license error occurs.
Thanks in advance for the help
ibnkureshi is offline   Reply With Quote
Old   March 10, 2010, 15:03
Default Cleaned Up the Script
Ibad Kureshi
I just realised that the script might be misleading as it is a sample one i usually use to experiment. I have cleaned it up:
#!/bin/bash
#PBS -S /bin/bash
#PBS -m e
#PBS -N fluent
#PBS -l nodes=3
#PBS -e stderr
#PBS -o stdout
#PBS -V
Old   March 11, 2010, 05:37
Ibad Kureshi
i was just wondering, would we need fluent-par licenses to submit a job like this through PBS?
when i submit of the commandline and specify multiple processors, it just takes away as many licenses it needs from the pool. But i was reading on another forum that through PBS fluent looks for fluent-par licenses. Is this really the case? Cant I just specify which pool it should take licenses from?
Old   June 8, 2011, 11:17
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
#!/bin/bash
#PBS -S /bin/bash
#PBS -m e
#PBS -N fluent
#PBS -l nodes=3
#PBS -e stderr
#PBS -o stdout
#PBS -V
Dear Mr. kureshi
If you are accessing the license server on a remote machine you on windows you must sepcify its IP address in the /etc/hosts file of the linux node. I havent tried this myself but one of my friend did that.
Also before that I recommend you to ping <IP remote PC> like ping 192.168.1.1 to see if your linux PC is seeing the remote one on the network? Then in the etc file as I said type
192.168.1.1 <license server name> <domain name>
192.168.1.1 node00 abc.ac.uk abc.ac.uk
Then try to run a serial solver first without a job scheduler to see if its picking the license or not.
If its OK go for parallel without job scheduler and then finally parallel with job scheduler. I hope it will work.
Shamoon Jamshed is offline   Reply With Quote
Old   June 9, 2011, 12:02
Ibad Kureshi
Hi Shamoon,
This was sorted a while ago. We have a DNS server that would translate the license server name. What I had not done was enable IP forwarding on the head node of the cluster. The job scheduler makes a node the simulation controller which books out the license. So when I would run directly it would work but through the script it would not work.
It was just a matter of enabling IPTABLES and setting the appropriate rules.
Thanks for your input though. If you would like any help do let me know
Regards
Ibad Kureshi
Lecturer: Department of Engineering and Technology
Administrator: High Performance Computing - Resource Centre
Postgraduate Researcher: School of Computing and Engineering
Canal Side East 2/13
University of Huddersfield
Queensgate
Huddersfield HD13DH
t: 01484 422288 ext 1855
Old   June 9, 2011, 13:43
Shamoon Jamshed
Hi Shamoon,
Regards
Ibad Kureshi
Queensgate
Huddersfield HD13DH
Thanks Mr. Kureshi
I assume that you are from Pakistan. Same as I. Well, in my case I am facing problem with Fluent 6.3. I have installed it on multiple nodes (workstations) and then when I try to run in parallel, on the head node it says after after few 1000 iterations "connection to license server lost". I don't know why is it so? I have license installed on each node because sometime i have to use them individually. I have ssh properly configured on each node plus I have password-less environment set. Remember that I do not use job scheduler.
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 12:56
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 14:22
solving ocean wave with Fluent or CFX? gholamghar Main CFD Forum 1 March 21, 2009 12:49
