June 13, 2011, 10:21 |
Inlet Turbulence Intensity
araz
I am simulating a complicated pipe and I am using k-e model with intensity and lenght scale at the velocity inlet boundary. the problem is, I found out that when you want to have contours of intensity inside the domain, the contours are calculated based on reference velocity, not your inlet velocity. now, my question is which intensity the solution is based on? the one I am giving explicitly at the inlet or the one calculated based on reference velocity? (the one I am giving is 15% and the one calculated is 70%!!) thx alot |
inlet boundary condition, intensity |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 06:58 |
High turbulence intensity | wenfengxie | FLUENT | 1 | April 16, 2010 12:00 |
turbulence intensity at inlet | raju | Main CFD Forum | 1 | November 16, 2006 00:13 |
turbulence intensity for skyscraper | antonella grassano | FLUENT | 0 | October 13, 2004 06:50 |
Low Turbulence Intensity Simulation | J. McCarthur | Main CFD Forum | 1 | October 26, 1999 16:17 |
