Convergence Problems in a T mixer
Old   June 13, 2011, 12:48
Default Convergence Problems in a T mixer
Nuno Gomes
Dinocrack is on a distinguished road
Hello All
I am simulating a mixing T reactor. I did the mesh with quadratic prismas, and the injectors(Top of the T) i use triangular primas and a tetrahedric. The skewness looks fine, under 0,85 for the differents case. I am trying a Reynolds number for 75, 150 and 300.
I doing, first simulations, with lower order discretizations (standard and 1st) with a constant velocty inlet. After i increase the order for Body(Because presto! dont converge) and Quick.
After that i try it with a parabolic velocity inlet UDF equation. For lower schemes its work fine but for higher schemes they converge but the residual ir higher(10e-2) compare to the first case(10e-4).
Any one can give clues or hints to resolve my problema....need any more information about my case?
Thank for your replys
Dinocrack is offline   Reply With Quote
Old   June 14, 2011, 06:10
Lightbulb
Nuno Gomes
Any one?! Plz...
continuity convergence problems in stirred tank nycera FLUENT 5 February 20, 2011 19:19
Weak rotational flow - Convergence Problems Daggemann FLUENT 1 May 8, 2009 09:45
NACA0012 Convergence Problems StudentAndrew CFX 6 November 21, 2005 06:49
Convergence problems Simone Siemens 5 June 29, 2005 10:48
Convergence problems Chetan FLUENT 3 April 15, 2004 19:13
