June 29, 2011, 05:24 |
Need help with Fluent Dynamic Mesh
ZHAO Yuqaio
Rep Power: 15 |
Dear all,
I'm a starter on using FLUENT, and I got lots of difficulties. Now I'm trying to learn dynamic mesh, and in the attachment is my first trial. I create a circle with one blade inside. The tip of the blade touches the internal rim of the circle. I would like to try to make the tip rotates about the center of the circle. However, I couldn't make it. "Negative Cell" occurs every single time I ran the "Mesh Motion". I hope that I could get some help here. Thank you guys sooooo much! |
June 29, 2011, 06:28 |
Rep Power: 15 |
Hi Bridges,
I have a question to you at first. How do you implement your text file in Fluent. What you wrote is no typical UDF-Code. Did you compile it? Try it with (omega_z 0 0 0.5). (omega_z 2 3 4) causes a movement around all three axes (x, y and z). As your mesh is only 2D, you get negative cells at once. The unit of angular velocity is rad/s. If the problem still arises, try to decrease your time step until it works. Good luck! Daniel |
dynamic mesh |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
FLUENT dynamic mesh set-up question | ral007 | FLUENT | 0 | February 15, 2011 12:28 |
Dynamic mesh + apaption in Fluent 12 ? | klunker | FLUENT | 0 | September 23, 2009 08:19 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
