Transient boundary condition with Fluent ANSYS12
Old   June 30, 2011, 12:10
Default Transient boundary condition with Fluent ANSYS12
djan
jetboo is on a distinguished road
hi everyone, i need to set a transient boundary condition for a pressure outlet.
I want it to decrease linearly from 160000 Pa to 60000 in 0.2 secs
With StarCCM+ i use this field function
($Time >= 0.2) ? -40000 : (60000-500000*$Time)
(the values are relatives to atmospheric pressure)
With fluent, i tried the profiles like stated in the manual (chapter7.1.9) but it doesnt seem to work. How can i do this either way ??
thx
Djan
jetboo is offline   Reply With Quote
Old   June 30, 2011, 12:23
Micael
Micael is on a distinguished road
I think the best way to do this is with an UDF. Something like that:
DEFINE_PROFILE(outlet_pressure,t,i)
 real pressure;
 face_t f;
 pressure = (CURRENT_TIME >= 0.2) ? -40000 : (60000-500000*CURRENT_TIME);
 begin_f_loop(f,t)
   F_PROFILE(f,t,i) = pressure;
 end_f_loop(f,t)
Also, keep in mind that FLUENT solver normally expect that outlet pressure is gauge pressure.
Micael is offline   Reply With Quote
Old   June 30, 2011, 12:40
djan
wow thank you,i didnt expect an answer so quickly i am really a novice in C so i dont get all of
what you wrote there but it seems to work so it's GREAT !
Can you explain the
face_t f;
line plz?
Old   June 30, 2011, 13:02
Micael
face_t is a data type specific to FLUENT. It is used to store an integer that identifies a particular face within a face thread (a boundary is a face thread). The macro begin_f_loop need it to work. Actually, begin_f_loop will give a value to the variable "f" that represents the current face under calculation. This value change at each loop. There is a lot of macro that use this value to give useful information about the given face, like its area or its temperature, as examples.
[Commercial meshers] icem fluent mesh with cyclic boundary condition jiejie OpenFOAM Meshing & Mesh Conversion 2 February 24, 2020 03:34
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 16:32
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
