June 29, 2011, 05:18 |
Time step for unsteady simulation
Mohankumar.G
Rep Power: 16 |
Hi
I am doing a simulation for defrosting of wind shield using fluent 12.1. In the input I am giving a time dependent temperature profile for 40min. For the unsteady calculation I am giving a time step of 5 sec and with intermediate iteration of 5. I am also getting solution for time step of 10 sec and I am getting a quicker solution as compare with 5 sec, but I want to know which is right and how to decide the time step for unsteady simulation. Thanks in advance. Mohan.G |
July 2, 2011, 14:40 |
Nik
Rep Power: 16 |
I would suggest, Monitor the temperature or the heat flux from the wind shield after a particular time interval.
If the difference between these monitored parameters is within some desired critera, say 5-8%, then you can trust the results of the 10 second case. Another way to deside whether your time step is correct as per grid and convection-diffusion of your physical problem is to check 1. CFL condition OR 2. Grid Fourier Number criterion ( Depending upon a physics of your problem) CFD criterion needs to be satisfied for negligible diffusion. Grid Fourier number criterion needs to be satisfied for negligible convection |
July 3, 2011, 23:51 |
Mohankumar.G
Rep Power: 16 |
Thank you Nikhil
July 4, 2011, 15:03 |
mecamor
Rep Power: 14 |
hello I wanted to see the shock wave generated by a piston. My problem I can not even move my piston with moving wall. thank you for helping me
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Time step in Transient simulation | sandisk | FLUENT | 2 | February 2, 2011 23:55 |
Long time CHT transient simulation time step.... | JP | CFX | 0 | May 9, 2008 03:36 |
