-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   Floating point error-invalid number (https://www.cfd-online.com/Forums/fluent/9024-floating-point-error-invalid-number.html)
Huong April 14, 2005 01:54
Would any one know why they appeal the message "Floating point error-invalid number" whenever I try to shown the contour. Thanks so much.
Alexander Starostin April 14, 2005 04:40
Re: Floating point error-invalid number
In particular if there is 1/x and x=0.
Huong April 17, 2005 20:49
So where should have that problem, do you have any ideas that where it come from?
Steve April 18, 2005 04:42
Probably bad code. If it's yours, use a debugger to trap the error. If you bought it, report the error to your vendor.
Specifically, if it's your code and it's written in Fortran, check that all your functions/subroutines have IMPLICIT NONE in them.
ag April 18, 2005 08:52
If this is a commercial plotting package like tecplot make sure you're not passing it results from a failed CFD run. That's the message tecplot spits out when you try to plot results from a run that has blown up.
Huong April 18, 2005 19:52
Re: Debugger ? Where can I find it?
Hi Steve,
YOu talking about debugger, where about in Fluent? Please point it out for me, thank you. Huong
Steve April 19, 2005 07:56
If it's Fluent spewing out bad values, send the problem to them. That's why you pay them.
nisrin March 12, 2010 11:43
floating point error
Originally Posted by Steve
;34026
Hi, I have been receiving this messege since long time" floating error" I did contact fluent people and no one is replying to my question. Is there any body who can help me, or is there anyone who can give me the right contact info for fluent people. thanks
sheikh nasir February 7, 2012 23:12
Hello, i am getting floating point error: invalid number. My thesis train moving in tunnel. Can any body help me. My email is sheikhnasir39@gmail.com
thanks
ertebatbama April 1, 2013 16:40
Floating point error: invalid number
:( hi all, I had same problem in fluent with a difference that my geometry is bended tube and my fluid is petroleum that part of this non-newtonian liquid is evaporate and this is two phase flow model - mixture.
I solve this problem by change (x or y direction) vector direction for mixture to Normal boundary in boundary condition menu for inlet
and i use adaption to solve this problem.
of course some times the ram are fulled when iteration is done or cpu or hardware is weak. for more help or detail go to following links
http://cfdonline.ir/forum/showthread.php?tid=119
http://www.cfd-online.com/Wiki/Fluent_FA...void_it.3F
good luck dears
HyperNova July 29, 2014 05:57
could you fix it Mr Sheikh Nasir ?! i have been working on this error for about 3 months but i could not :(((
HyperNova July 29, 2014 06:01
Could any body here fix this error ? please help me I need it quick , my email : bkianoush@mail.kntu.ac.ir
HyperNova July 30, 2014 07:42
Does any body here can help me ? i really need fix this peoblem
Yoo Rin July 21, 2017 03:24
Hi HyperNova. Have you fix your problem?
HyperNova July 23, 2017 10:54
Hi, explain your problem, and when u face this error.
