July 12, 2011, 02:01 |
Drag coefficient error
Josh
Rep Power: 14 |
Hi all,
I'm relatively new to CFD and could use a few pointers on my following problem. I'm using Gambit 2.4.6 to generate a NACA0006 airfoil then Fluent 13 to calculate lift and drag coefficients at several angles of attack. Reynolds number is 3e6, laminar model, pressure based solver. I have refined the mesh several times and have converged on a lift and drag value for each case. Comparing to Xfoil and 'Theory of Wing Sections' my lift is in the order of 2-7% accurate but for almost every case my drag is approximately double. I've tried to refine the mesh further close to the airfoil surface but after a certain level of refinement my continuity residual no longer converges. Thoughts? Regards, Josh |
July 13, 2011, 16:12 |
Ryne
Rep Power: 16 |
What turbulence model are you using?
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
