July 14, 2011, 16:21 |
Implicit Timestep
Hi, I had a quick question dealing with time steps in an implicit solution. I am dealing with transient system and finding that 1e-7 was taking to long to stabilize, so during the middle of the simulation i stopped and changed the time step to 1e-6. My question is will this introduce error, I do fully understand higher time step yields solution faster with less accuracy, my question deals more with am I creating a hole or effecting the results in a way that would invalidate them.
So I guess I am asking, does changing the time step create unacceptable noise in the solution after the change. I am actually only interested in the steady state solution, so I am not sure if it even matters. |
July 21, 2011, 00:59 |
It is a common practice, for unsteady flows, to start with a low TS and then gradually increase it as time progresses. It will not affect your flow as long as the higher TS leads to a converged flow. Check the value of Courant Number in your domain whenever you adjust the TS, a value <10 should be acceptable.
Restart 2-way FSI with different timestep? | Lance | CFX | 10 | April 17, 2013 00:37 |
Help. implicit discritization | dearboy | Main CFD Forum | 0 | November 25, 2010 21:46 |
need for an unsteady implicit solver suitable for large timestep | dinonettis | OpenFOAM | 2 | May 26, 2010 06:57 |
Can anyone explain the difference between these implicit concepts? | bearcat | Main CFD Forum | 0 | February 20, 2010 18:39 |
Use of Timestep in obtaining solution. | hagupta | CFX | 7 | February 28, 2006 13:14 |
