WARNING: Periodic face x in zone y is not pointing to the right shadow. |
July 18, 2011, 16:25 |
WARNING: Periodic face x in zone y is not pointing to the right shadow. Does anyone know what this means and how would I go about fixing it?
Thanks |
September 30, 2011, 09:42 |
Brian
It means that the periodic specification in your mesh isn't right. In FLUENT, go to >Define>Boundary Conditions, select your periodic zone and hit "Edit". Check that the periodicity type is correctly selected as translational or rotational to match your geometry. This isn't the only thing that can cause this error in mesh check, but it's probably the most common one.
periodic |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
